.. _configuring-vscode: ================================================================================ Configuring Visual Studio Code ================================================================================ .. contents:: :depth: 1 :local: VSCode is the recommended IDE for working with the ODrive codebase. It is a light-weight text editor with Git integration and GDB debugging functionality. Before doing the VSCode setup, make sure you've installed all of your :ref:`prerequisites. ` Setup Procedure -------------------------------------------------------------------------------- #. Clone the ODrive repository #. `Download VSCode `_ #. Open VSCode #. Install extensions. This can be done directly from VSCode (:kbd:`Ctrl` **+** :kbd:`Shift` **+** :kbd:`X`) * Required extensions: * C/C++ :code:`ext install ms-vscode.cpptools` * Cortex-Debug :code:`ext install marus25.cortex-debug` * Cortex-Debug: Device Support Pack - STM32F4 :code:`ext install marus25.cortex-debug-dp-stm32f4` * Recommended Extensions: * Include Autocomplete * Path Autocomplete * Auto Comment Blocks #. Create an environment variable named :code:`ARM_GCC_ROOT` whose value is the location of the :code:`GNU Arm Embedded Toolchain` (.e.g :code:`C:\Program Files (x86)\GNU Tools Arm Embedded\7 2018-q2-update`) that you installed in the prerequisites section of the developer's guide. This is not strictly needed for Linux or Mac, and you can alternatively use the :code:`Cortex-debug: Arm Toolchain Path` setting in VSCode extension settings. #. Relaunch VSCode #. Open the VSCode Workspace file, which is located in the root of the ODrive repository. It is called :code:`ODrive_Workspace.code-workspace`. The first time you open it, VSCode will install some dependencies. If it fails, you may need to `change your proxy settings `_. You should now be ready to compile and test the ODrive project. Building the Firmware -------------------------------------------------------------------------------- * **Terminal** -> **Run Build Task** (:kbd:`Ctrl1` **+** :kbd:`Shift` **+** :kbd:`B`) A terminal window will open with your native shell. VSCode is configured to run the command :code:`make -j4` in this terminal. Flashing the Firmware -------------------------------------------------------------------------------- * **Terminal** -> **Run Task** -> **flash** A terminal window will open with your native shell. VSCode is configured to run the command :code:`make flash` in this terminal. If the flashing worked, you can connect to the board using the :ref:`odrivetool `. Debugging -------------------------------------------------------------------------------- An extension called Cortex-Debug has recently been released which is designed specifically for debugging ARM Cortex projects. You can read more on Cortex-Debug `here. `_ Note: If developing on Windows, you should have :code:`arm-none-eabi-gdb` and :code:`openOCD` on your PATH. * Make sure you have the Firmware folder as your active folder * Set :code:`CONFIG_DEBUG=true` in the tup.config file * Flash the board with the newest code (starting debug session doesn't do this) * In the **Run** tab (:kbd:`Ctrl` **+** :kbd:`Shift` **+** :kbd:`D`), select "Debug ODrive (Firmware)" * Press **Start Debugging** (or press :kbd:`F5`) * The processor will reset and halt. * Set your breakpoints. Note: you can only set breakpoints when the processor is halted, if you set them during run mode, they won't get applied. * **Continue** (press :kbd:`F5`) * Stepping over/in/out, restarting, and changing breakpoints can be done by first pressing the "pause" (F6) button at the top the screen. * When done debugging, simply stop (:kbd:`Shift` **+** :kbd:`F5`) the debugger. It will kill your openOCD process too. Cleaning the Build -------------------------------------------------------------------------------- This sometimes needs to be done if you change branches. * Open a terminal (**View** -> **Integrated Terminal**) and enter :code:`make clean`
