.. _configuring-eclipse: ================================================================================ Setting up Eclipse development environment ================================================================================ .. contents:: :depth: 1 :local: Install ------------------------------------------------------------------------------- * Install `Eclipse IDE for C/C++ Developers. `_ * Install the `OpenOCD Eclipse plugin. `_ Import Project ------------------------------------------------------------------------------- * **File** -> **Import** -> **C/C++** -> Existing Code as Makefile Project * Browse for existing code location, find the OdriveFirmware root. * In the Toolchain options, select `Cross GCC` * Hit **Finish** * Build the project (press :kbd:`ctrl-B`) .. figure:: figures/CodeAsMakefile.png :scale: 50 % :alt: Toolchain options Load the Launch Configuration ------------------------------------------------------------------------------- * **File** -> **Import** -> **Run/Debug** -> **Launch Configurations** -> **Next** * Highlight (don't tick) the OdriveFirmare folder in the left column * Tick OdriveFirmware.launch in the right column * Hit **Finish** .. figure:: figures/ImportLaunch.png :scale: 50 % :alt: Launch Configurations Launch! ------------------------------------------------------------------------------- * Make sure the programmer is connected to the board as per :ref:`Flashing the firmware `. * Press the down-arrow of the debug symbol in the toolbar, and hit Debug Configurations * You can also hit **Run** -> **Debug Configurations** * Highlight the debug configuration you imported, called OdriveFirmware. If you do not see the imported launch configuration rename your project to `ODriveFirmware` or edit the launch configuration to match your project name by unfiltering unavailable projects: .. figure:: figures/LaunchConfigFilter.png :scale: 50 % :alt: Launch Configurations Filters * Hit **Debug** * Eclipse should flash the board for you and the program should start halted on the first instruction in `Main` * Set beakpoints, step, hit Resume, etc. * Make some cool features! ;D
