ASCII Protocol
Sending Commands
- Via USB:
Windows: Use PuTTY to manually send commands or open the COM port using your favorite programming language
Linux/macOS: Run
/dev/tty*to list all serial ports. The ODrive will show up as/dev/ttyACM0(or similar) on Linux and/dev/tty.usbmodem[...]on macOS. Once you know the name, you can usescreen /dev/ttyACM0(with the correct name) to send commands manually or open the device using your favorite programming language. Serial ports on Unix can be opened, written to and read from like a normal file.
- Via UART: Connect the ODrive’s TX to your host’s RX, and the ODrive’s RX to your host’s TX. See UART for more info.
Arduino: You can use the ODrive Arduino library to talk to the ODrive.
Windows/Linux/macOS: You can use an FTDI USB-UART cable to connect to the ODrive.
The ODrive does not echo commands. That means that when you type commands into a program like screen, the characters you type won’t show up in the console.
Arduino
There is an Arduino library that gives some examples on how to use the ASCII protocol to communicate with the ODrive. Check it out here <../Arduino/ODriveArduino>.
Command Format
The ASCII protocol is human-readable and line-oriented, with each line having the following format:
Format: command *42 ; comment [new line character]
*42stands for a GCode compatible checksum and can be omitted. If and only if a checksum is provided, the device will also include a checksum in the response, if any. If the checksum is provided but is not valid, the line is ignored. The checksum is calculated as the bitwise xor of all characters before the asterisk (*). Example of a valid checksum:r vbus_voltage *93.Comments are supported for GCode compatibility.
The command is interpreted once the new-line character is encountered.
If the command yields a response but the ODrive hasn’t finished sending the previous response yet, the new response is silently discarded.
Supported new-line characters are carriage return (
\r), line feed (\n), CR/LF (\r\n), and!.The ODrive will always use CR/LF (
\r\n) as the new-line termination sequence
Command Reference
Motor Trajectory
For moving the axis from point to point, this is the recommended command and mode. Make sure to set up the trapezoidal trajectory parameters first.
Format: t motor destination
tfor trajectory.motoris the motor number,0or1.destinationis the goal position, in [turns].
Example:
t 0 -2
This command sets the control mode to CONTROL_MODE_POSITION_CONTROL and the input mode to INPUT_MODE_TRAP_TRAJ This command updates the watchdog timer for the motor.
Motor Position
For basic use where you send position setpoints, use the q command, recommended together with filtered position input mode for general use.
Format: q motor position velocity_lim torque_lim
qfor position.motoris the motor number,0or1.positionis the desired position, in [turns].velocity_limis the velocity limit, in [turns/s] (optional).torque_limis the torque limit, in [Nm] (optional).
Example:
q 0 -2 1 0.1
This command sets the control mode to CONTROL_MODE_POSITION_CONTROL This command updates the watchdog timer for the motor.
Motor Position with feed-forward
If you have a realtime controller that is streaming setpoints and tracking a trajectory, use the p command.
Format: p motor position velocity_ff torque_ff
pfor positionmotoris the motor number,0or1.positionis the desired position, in [turns].velocity_ffis the velocity feed-forward term, in [turns/s] (optional).torque_ffis the torque feed-forward term, in [Nm] (optional).
Example:
p 0 -2 0 0
If you don’t know what feed-forward is or what it’s used for, simply omit it.
Motor Velocity
Format: v motor velocity torque_ff
vfor velocitymotoris the motor number,0or1.velocityis the desired velocity in [turns/s].torque_ffis the torque feed-forward term, in [Nm] (optional).
Example:
v 0 1 0
This command sets the control mode to CONTROL_MODE_VELOCITY_CONTROL This command updates the watchdog timer for the motor.
Motor Torque
Format: c motor torque
cfor torquemotoris the motor number,0or1.torqueis the desired torque in [Nm].
This command sets the control mode to CONTROL_MODE_TORQUE_CONTROL This command updates the watchdog timer for the motor.
Request Feedback
input format: f motor
response format: pos vel
ffor feedback.posis the encoder position in [turns] (float).velis the encoder velocity in [turns/s] (float).
Update Motor Watchdog
Format: u motor
ufor /u/pdate.motoris the motor number,0or1.
This command updates the watchdog timer for the motor, without changing any setpoints.
Set Absolute Position
Format: es motor abs_pos
eslfor encoder set (abs pos).motoris the motor number,0or1.abs_posthe absolute position to set the current position to.
Sets the absolute position of the axis
Parameter Reading/Writing
Not all parameters can be accessed via the ASCII protocol but at least all parameters with float and integer type are supported.
Reading format:
r [property]
propertyname of the property, as seen in ODrive Toolresponse: text representation of the requested value
Example:
r vbus_voltage=> response:24.087744Writing format:
w [property] [value]
valuetext representation of the value to be writtenExample:
w axis0.controller.input_pos -123.456
System Commands
ss- Save configse- Erase configsr- Rebootsc- Clear errors
