Python Package
The odrive Python package provides an easy and intuitive way to control
one or multiple ODrives from a Python script.
The package also contains the interactive command line tool odrivetool.
odrivetool is documented separately here, whereas this page is for users who want to write scripts.
System Requirements
Python 3.7 or higher
Operating System:
Linux based on glibc 2.28 or higher (Ubuntu ≥ 20.04 / Debian ≥ 10 / …) (x86_64, ARM64)
Windows 10 or higher (x86_64)
macOS 12.0 (Monterey) or higher (Apple Silicon, Intel)
If you are constrained to a system that is not supported, please contact us.
Full compatibility with all current generation ODrives (ODrive Pro, S1, Micro) on all firmware versions
Basic compatibility with ODrive v3.x, firmware v0.3.0 or higher
Installation
Quick install, if you’ve already done this kind of thing:
python3 -m pip install --upgrade odrive
For detailed instructions and troubleshooting, see: odrivetool Installation.
Basic Example
This example assumes that you have already configured the ODrive in the GUI so that it’s ready for position control and you now want to control it from Python.
Discover the ODrive (see also Discovery Use Cases):
import odrive odrv0 = odrive.find_sync()
Enter closed loop control:
from odrive.enums import AxisState from odrive.utils import request_state request_state(odrv0.axis0, AxisState.CLOSED_LOOP_CONTROL)
Run a sine wave:
import math import time p0 = odrv0.axis0.controller.input_pos t0 = time.monotonic() while odrv0.axis0.current_state == AxisState.CLOSED_LOOP_CONTROL: setpoint = p0 + 4.0 * math.sin((time.monotonic() - t0) * 2) # [rev] print(f"goto {setpoint}") odrv0.axis0.controller.input_pos = setpoint time.sleep(0.01)
If the loop exits for any reason, show errors:
from odrive.utils import dump_errors dump_errors(odrv0)
The object odrv0 in this example can be used exactly like in the interactive odrivetool shell.
See ODrive API Reference for a list of all available properties and functions on the ODrive.
Async Usage
Interacting with ODrives is mostly I/O-oriented, therefore asynchronous
programming is a natural fit. It allows for thread-like concurrency but in a
single thread (learn more for example here).
The odrive package can be used seamlessly with Python’s
async/await syntax and asyncio library.
To turn your ODrive script into an async script, start by replacing odrive.find_sync() with await odrive.find_async().
This will return an ODrive object that is suitable for use in async/await code.
find_async() behaves almost identically to find_sync(), except
that all I/O operations become awaitable and the syntax for reading/writing properties changes.
Summary of the differences:
Discovery
odrv0 = odrive.find_sync() # Sync odrv0 = await odrive.find_async() # Async
Reading properties
pos = odrv0.axis0.pos_estimate # Sync pos = await odrv0.axis0.pos_estimate.read() # Async
Writing properties
odrv0.axis0.controller.input_pos = 5.0 # Sync await odrv0.axis0.controller.input_pos.write(5.0) # Async
Using util functions
from odrive.utils import request_state request_state(odrv0.axis0, AxisState.CLOSED_LOOP_CONTROL) # Sync await request_state(odrv0.axis0, AxisState.CLOSED_LOOP_CONTROL) # Async
Asynchronous ODrive objects are not thread-safe. They must only be used on the
thread that was used for discovery and manages the backend. Multithreaded
synchronous and single-threaded asynchronous styles can be mixed with
odrive.utils.to_sync() and odrive.utils.to_async().
Discovery Use Cases
The examples below are for Async Usage. For synchronous usage, replace
find_async() with find_sync().
Wait for first ODrive that is connected:
Discover ODrive by serial number:
odrv0 = await odrive.find_async(serial_number="3348373D3432")
Discover multiple ODrives by serial number:
odrv0, odrv1 = await odrive.find_async(serial_numbers=["3348373D3432", "336437623432"])
Discover multiple ODrives with unknown serial number:
odrv0, odrv1 = await odrive.find_async(count=2)
Advanced dynamic handling of ODrives as they are connected and disconnected:
from odrive.device_manager import get_device_manager, Subscription def on_found(dev): print(f"found device with serial number {dev.info.serial_number}") return True # connect def on_lost(dev): print("lost device") def on_connected(dev): print("connected to device") def on_disconnected(dev): print("device disconnected") subscription = Subscription(on_found, on_lost, on_connected, on_disconnected) get_device_manager().subscribe(subscription)
Best Practices
CAN is considered more reliable than USB for runtime operation. Full CAN support in the Python package is coming soon. Until then, if you want to use CAN, see separate CAN Bus Guide.
For initial development, it is recommended to set up the ODrive via the Web GUI and use the Python script only for runtime operation. Once it works as desired, you can export the config commands from the GUI (Configuration tab) and use Python to (re-)commission the ODrives in your application programmatically.
Keep ODrive setup (config & calibration) separate from runtime operation in the code. For fast iteration and easy debugging, you should be able to run either one without the other.
While in
CLOSED_LOOP_CONTROL, continuously monitor<axis>.current_stateto check if the ODrive stopped for any reason. If it stopped, inspect the error<axis>.disarm_reason. Depending on the error and on your application, restart the axis either automatically or upon user action.Expect USB disconnects: On the ODrive side, enable the watchdog timer. On the Python side, ongoing operations (read, write, function calls) would fail with
DeviceLostExceptionon disconnect. CatchDeviceLostException, reconnect and treat it as any other axis error by restarting the axis (automatically or upon user interaction, depending on your application).
Reference
odrive
- exception odrive.DeviceLostException(device: Device)
Exception that is thrown when any operation fails because the underlying device was disconnected.
- odrive.find_any(*args, **kwargs)
Alias for
find_sync().
- async odrive.find_async(serial_number: ~typing.Sequence[str] | str | None = None, count: int | None = None, return_type: ~typing.Type[~odrive.device_manager.T] = <class 'odrive.async_tree.AsyncObject'>, device_type: ~odrive.libodrive.DeviceType | None = None) T
Waits until one or multiple ODrives are found and connected.
This is a wrapper around
odrive.device_manager.DeviceManager.wait_for().If the device manager was not initialized yet, it is initialized and bound to the current thread and event loop.
If a timeout is needed, consider wrapping this in
asyncio.wait_for(find_any(...), timeout).For a blocking, thread-safe wrapper, see
find_sync().
- odrive.find_sync(serial_number: ~typing.Sequence[str] | str | None = None, count: int | None = None, return_type: ~typing.Type[~odrive.device_manager.T] = <class 'odrive.sync_tree.SyncObject'>, timeout: float = None) T
This is a blocking, thread-safe wrapper around
odrive.device_manager.DeviceManager.wait_for().If the device manager was not initialized yet, this starts a background thread to run the backend.
For use with async/await, see
find_async().
odrive.utils
Convenience functions for working with ODrives.
All members of odrive.utils are exposed directly in the
odrivetool console but can also be used in user scripts.
- odrive.utils.backup_config(device: RuntimeDevice | AsyncObject | SyncObject) dict
Returns a dict of the form {path: value} containing all properties on the ODrive that have “config” in their path.
- Parameters:
device – The device to read from
- odrive.utils.dump_errors(odrv: RuntimeDevice | AsyncObject | SyncObject, clear: bool = False)
Prints a summary of the error status of the device on stdout.
If you need the errors as a string instead, see
format_errors().
- async odrive.utils.format_errors(odrv: RuntimeDevice, clear: bool = False)
Returns a summary of the error status of the device formatted as
RichText.
- odrive.utils.request_state(axis: AsyncObject | SyncObject, state: AxisState)
Requests an axis to enter the specified state.
No effect if the axis is already in that state.
- odrive.utils.restore_config(device: RuntimeDevice | AsyncObject | SyncObject, config: Dict[str, Any] | Tuple[str, Any])
Restores the configuration of the ODrive from a dictionary.
- Parameters:
device – The ODrive to write the config to.
config – A dictionary of the form {path: value} or a list of tuples given in the form [(path: value)]
- odrive.utils.run_state(axis: AsyncObject | SyncObject, state: AxisState)
Runs the requested state and waits until it finishes.
Example:
run_state(odrv0.axis0, AxisState.MOTOR_CALIBRATION)
Upon entering, all pending errors are cleared (
clear_errors()). After entering the requested axis state, the function continuously polls the state and feeds the watchdog at 5Hz. If the state finishes successfully, the function returns normally. If the state finishes with an error, the function raises aodrive.exceptions.DeviceStateException. If the function is cancelled, the ODrive axis is commanded toIDLE.
- odrive.utils.start_liveplotter(properties: List[AsyncProperty], layout: List[List[str]] | None = None, window_size: float = 5.0)
Starts the liveplotter. See also Liveplotter.
This function returns immediately, it does not block until the plot is closed. The liveplotter can be stopped by closing the figure or calling
stop_liveplotter().Raises an exception if a liveplotter is already open.
- Parameters:
properties – A list of ODrive properties that shall be read.
layout – An optional nested list of keys that defines the subplots and the ordering of data within each subplot. Each string is a name of a plotted property, e.g. “axis0.pos_estimate”. If multiple ODrives are plotted, prepend the ODrive name. Each list of strings correspond to one subplot. If omitted, all properties are shown on a single subplot.
window_size – The size of the x-axis in number of samples.
- odrive.utils.stop_liveplotter()
Stops the currently running liveplotter.
- odrive.utils.to_async(odrv: RuntimeDevice | AsyncObject | SyncObject)
Converts an ODrive object that was obtained for synchronous usage (
find_sync()) to an object that is suitable for asynchronous usage (see Async Usage).The returned object must only be used on the same thread as the device manager (
get_device_manager()).
- odrive.utils.to_sync(odrv: RuntimeDevice | AsyncObject | SyncObject)
Converts an ODrive object that was obtained for asynchronous usage (
find_async()) to an ODrive object that is suitable for synchronous usage (see Async Usage).The returned object is thread-safe.
- class odrive.device_manager.DeviceManager(loop: AbstractEventLoop, lib: LibODrive)
- subscribe(subscription: Subscription)
Adds a subscription to this device manager that will be notified when a matching device appears / disappears.
The subscription is also notified for all matching devices already present.
- async wait_for(serial_number: ~typing.Sequence[str] | str | None = None, count: int | None = None, return_type: ~typing.Type[~odrive.device_manager.T] = <class 'odrive.runtime_device.RuntimeDevice'>, device_type: ~odrive.libodrive.DeviceType = None) T
If no arguments are given, the function waits for a single ODrive.
Specific ODrives can be selected by specifying their serial number. If the serial numbers are not known,
countcan be specified to wait for a certain number of ODrives.The return type is either a single ODrive object (if no arguments are given or
serial_numberis given as a string) or a tuple of ODrives otherwise.The ODrives that this function connects to are claimed for exclusive use by the current Python process and cannot be used by any other programs. Other ODrives are not claimed and can still be used by other programs.
Can be called multiple times, including simultaneously, from multiple async tasks on the same thread. Calls from multiple threads are not allowed. The returned ODrive object must not be used from any other thread than the one it was retrieved on (exception: if
return_typeisSyncObject).See also: Discovery Use Cases,
get_device_manager(),odrive.find_sync(),odrive.find_async().- Parameters:
serial_number – Single serial number or sequence (e.g. tuple or list) of multiple serial numbers. None to accept any serial number. If a sequence is specified, the returned tuple is in the same order.
count – Number of ODrives to wait for. Must be None if
serial_numberis specified.
- class odrive.device_manager.Subscription(on_found: Callable[[Device], bool], on_lost: Callable[[Device], None], on_connected: Callable[[RuntimeDevice], None], on_disconnected: Callable[[RuntimeDevice], None], debug_name: str)
Subscription to be used with
DeviceManager.subscribe().- Parameters:
on_found – Called when a device is found. The serial number is already available before the device is connected, so the application can use this callback to decide if the device shall be connected. The handler shall return
Trueto request connection andFalseto ignore the device. If connection is requested,on_connectedis called later. If multiple subscriptions are active, a connection is opened if any subscription accepts the device. Otherwise, if no subscription requests a connection, the device can be used by other applications.on_lost – Called when a device is lost.
on_connected – Called when a connection with the device is established.
on_disconnected – Called when a device that was previously announced via
on_connectedis disconnected.
- odrive.device_manager.close_device_manager()
Closes the global
DeviceManagerobject (if it is open). All devices associated with it must be considered invalid after calling this.This is called automatically upon exit of the program.
- odrive.device_manager.get_device_manager() DeviceManager
Returns the global
DeviceManagerobject. The first call to this function instantiates the device manager, initializes the backend and starts USB discovery.The first call also defines which thread and asyncio event loop the device manager is bound to:
If the current thread has an event loop, the device manager is bound to the current thread and event loop.
If the current thread has no event loop, a background thread with an event loop is started.
Subsequent calls return the same device manager, until
close_device_manager()is called.The device manager and devices returned by it must only be used on the thread that it is bound to. An exception are the thread safe wrapper objects returned by
odrive.find_sync()andodrive.utils.to_sync().
