CAN Protocol
This document describes the CAN Protocol. For examples of usage, check out our CAN Guide!
CAN Frame
At its most basic, a CAN Simple message ID is 11 bits, interpreted as follows:
  • Upper 6 bits - Node ID - max 0x3F
  • Lower 5 bits - Command ID - max 0x1F
For example, an Axis ID of 0x01 with a command of 0x0C would be result in a message ID 0x2C:
can_id = axis_id << 5 | cmd_id
0x01 << 5 | 0x0C = 0x2C
Messages
See the .dbc file for the description of all messages. We recommend the free CANdb++ software from Vector for viewing and editing this database.
CAN Messages
CMD ID
Name
Sender
Signals
Start Byte
Signal Type
Bits
Factor
Offset
0x000
Get_Version
ODrive_Axis0
Protocol_Version
Hw_Version_Major
Hw_Version_Minor
Hw_Version_Variant
Fw_Version_Major
Fw_Version_Minor
Fw_Version_Revision
Fw_Version_Unreleased
0
3
4
5
6
7
Unsigned Int
Unsigned Int
Unsigned Int
Unsigned Int
Unsigned Int
Unsigned Int
Unsigned Int
Unsigned Int
8
8
8
8
8
8
8
8
0
0
0
0
0
0
0
0x001
Heartbeat
ODrive_Axis0
Axis_Error
Axis_State
Procedure_Result
Trajectory_Done_Flag
0
4
5
6
Unsigned Int
Unsigned Int
Unsigned Int
Unsigned Int
32
8
8
0
0
0
0x002
Estop
Master
0x003
Get_Error
ODrive_Axis0
Active_Errors
Disarm_Reason
0
4
Unsigned Int
Unsigned Int
32
32
0
0x004
RxSdo
None
Endpoint_ID
Unsigned Int
16
0x005
TxSdo
None
Endpoint_ID
Unsigned Int
16
0x006
Set_Axis_Node_ID
Master
Axis_Node_ID
0
Unsigned Int
32
0x007
Set_Axis_State
Master
Axis_Requested_State
0
Unsigned Int
32
0x009
Get_Encoder_Estimates
ODrive_Axis0
Pos_Estimate
Vel_Estimate
0
4
IEEE 754 Float
IEEE 754 Float
32
32
0
0x00b
Set_Controller_Mode
Master
Control_Mode
Input_Mode
0
4
Unsigned Int
Unsigned Int
32
32
0
0x00c
Set_Input_Pos
Master
Input_Pos
Vel_FF
Torque_FF
0
4
6
IEEE 754 Float
Signed Int
Signed Int
32
16
16
0.001
0
0
0
0x00d
Set_Input_Vel
Master
Input_Vel
Input_Torque_FF
0
4
IEEE 754 Float
IEEE 754 Float
32
32
0
0x00e
Set_Input_Torque
Master
Input_Torque
0
IEEE 754 Float
32
0x00f
Set_Limits
Master
Velocity_Limit
Current_Limit
0
4
IEEE 754 Float
IEEE 754 Float
32
32
0
0x011
Set_Traj_Vel_Limit
Master
Traj_Vel_Limit
0
IEEE 754 Float
32
0x012
Set_Traj_Accel_Limits
Master
Traj_Accel_Limit
Traj_Decel_Limit
0
4
IEEE 754 Float
IEEE 754 Float
32
32
0
0x013
Set_Traj_Inertia
Master
Traj_Inertia
0
IEEE 754 Float
32
0x014
Get_Iq
ODrive_Axis0
Iq_Setpoint
Iq_Measured
0
4
IEEE 754 Float
IEEE 754 Float
32
32
0
0x015
Get_Temperature
ODrive_Axis0
FET_Temperature
Motor_Temperature
0
4
IEEE 754 Float
IEEE 754 Float
32
32
0
0x016
Reboot
Master
0x017
Get_Bus_Voltage_Current
ODrive_Axis0
Bus_Voltage
Bus_Current
0
4
IEEE 754 Float
IEEE 754 Float
32
32
0
0x018
Clear_Errors
Master
0x019
Set_Absolute_Position
Master
Position
0
IEEE 754 Float
32
0x01a
Set_Pos_Gain
Master
Pos_Gain
0
IEEE 754 Float
32
0x01b
Set_Vel_Gains
Master
Vel_Gain
Vel_Integrator_Gain
0
4
IEEE 754 Float
IEEE 754 Float
32
32
0
0x01c
Get_Torques
ODrive_Axis0
Torque_Target
Torque_Estimate
0
4
IEEE 754 Float
IEEE 754 Float
32
32
0
0x01d
Get_Controller_Error
ODrive_Axis0
Controller_Error
0
Unsigned Int
32
0x01f
Enter_DFU_Mode
Master
  • Messages labeled GET_ are call & response. The Master node sends a message with the RTR bit set, and the axis responds with the same ID and specified payload.
  • The CANopen NMT message is reserved by CANSimple. It is not currently used or implemented.
  • All multibyte values are little endian (aka Intel format, aka least significant byte first).
Cyclic Messages
Cyclic messages are sent by ODrive on a timer without a request. The cycle times can be configured for each axis, see axis.config.can. A cycle time of 0 disables the message.
Watchdog
Each valid CAN message resets the ODrive Watchdog. If CAN communication is disrupted and the watchdog expires, the axis will be put into IDLE. See axis.config.enable_watchdog for more information.
DBC Files
The CANSimple .dbc file for each firmware version can be downloaded here.
Interoperability with CANopen
You can deconflict with CANopen like this:
  • odrv0.axis0.config.can.node_id = 0x010 - Reserves messages 0x200 through 0x21F
  • odrv0.axis1.config.can.node_id = 0x018 - Reserves messages 0x300 through 0x31F
It may not be obvious, but this allows for some compatibility with CANOpen. Although the address space 0x200 and 0x300 correspond to receive PDO base addresses, we can guarantee they will not conflict if all CANopen node IDs are >= 32. E.g.:
  • CANopen nodeID = 35 = 0x23
  • Receive PDO 0x200 + nodeID = 0x223, which does not conflict with the range [0x200 : 0x21F]
Be careful that you don’t assign too many nodeIDs per PDO group. Four CAN Simple nodes (32*4) is all of the available address space of a single PDO. If the bus is strictly ODrive CAN Simple nodes, a simple sequential Node ID assignment will work fine.
